Marantz AV7701 Pre Tune
0 Members and 1 Guest are viewing this topic. Read 920 times.
rab1234
« on: 16 Nov 2014, 06:17 pm »
I have looked and looked in the Marantz AV77701 Owners Manual for a way to change channel levels and distances from those set within the Audyssey setup values to flat settings  ie; (0db for both left and right channels) and equal values (such as; 13' for both left and right channels) by some how using the units memory to easily change settings back and fort.
Another way of describing what I'm trying to accomplish includes disabling the room acoustics effect to flat without having to change levels back and forth utilizing memory functions some how.
Thank you for any help you can provide.
youravhandyman
Re: Marantz AV7701 Pre Tune
« Reply #1 on: 17 Nov 2014, 08:23 pm »
Full configuration within Audyssey requires a pro license for your device and someone with the pro setup software.  You can turn off Audyssey and set manual distance parameters within the setup configuration though it has been some time since I have sat down in front of one for me to help you find the settings.
Matt
