Acoustic Energy Aelite 3 Floorstanding Speakers Mint Condition Maple wood
0 Members and 1 Guest are viewing this topic. Read 3772 times.
dvzzz
Selling this pair of award-winning British speakers from Acoustic Energy for $670. If you are reading this you probably know Acoustic Energy. This genuine example of British sound Aelite 3 is a genuine class act, and clearly among the best of the models in the price tier up to $2500.
The exceptionally fine neutrality and attendant low level of coloration. The sound has plenty of weight, does not require a subwoofer even in the larger room thanks to the design decision to use second passive radiator - there is the option to block any combination of the three ports gives great flexibility. And while the bass end is certainly weighty, it's also impressively smooth and even (with the ports open).
Stereo focus is another major strength, and any enclosure coloration is very well controlled, ensuring fine transparency, too. However, the top end is smooth and well ordered, speech is particularly clean, open and natural, showing remarkable similarly to a BBC LS 3/5a monitor, a hard benchmark to beat.
<p>
I bought them for $1900 but downsizing now. Acoustically-matched pair, sequential serial numbers. What you see in the picture is exactly what I am selling. Please note both speakers are exactly same color, just camera white balance issue. Orignal boxes are included with manual, all jumpers and connecter plugs are present.
Local pickup in Chicagoland is preferred but I am not opposed to shipping, I have original boxes. UPS or FedEx package weight 2x40lbs.<p>
HF uniit:
25mm neodymium tweeter with high dispersion diaphragm. Ferrofluid cooled and damped.
Magnetically shielded. Exclusively Profiled
MF Unit:
110mm mid range driver with 32mm short throw voice coil, die cast chassis, high power, magnet system and lightweight alloy cone. Magnetically shielded
LF Unit:
Twin 125mm mid/bass drivers with 26mm voice coil, die cast chassis, high power, magnet system and lightweight alloy cone. Magnetically shielded
Power Handling:
175 watt max
Overall Frequency Response:
34Hz – 27kHz
Sensitivity:
89dB
Impedance:
8 Ohms
Cabinet:
Real wood veneered.15mm MDF wrap. Twin vented horizontal bracing. High power, back firing, low turbulence bass-reflex ports.22mm front baffle
Terminals:
Gold-plated 4-way binding posts
Dimensions:
9" x 36" x 11.6" (WxHxD)
Weight:
40 lbs (single, unpacked) Shipping weight will be 2x45lbs.
<p>
sonus faber naim tannoy klipsch nola harbeth spendor rogers monitor audio wilson dali jbl research proac kef
focal atc dynaudio tekton T+A PSB paradigm totem energy vandersteen martin logan joseph vienna definitive technology
golden ear usher legacy avalon b&W rel revel bowers wilkins wilson thiel vienna nht snell linn rega magico emerald fritz
krell tad reference ae1
« Last Edit: 17 Nov 2014, 01:10 am by dvzzz »
