0 Members and 1 Guest are viewing this topic. Read 5511 times.
What I'd like to see is a larger driver, like a 5" or 6" or maybe even an 8" used in conjunction (maybe crossoverless) with one if these 3" drivers. I think that could work really well and would largely relieve the 3" driver of producing midbass and bass...
Could you elaborate on how the 3" could be relieved of bass without a crossover?
Being the Single Driver Circle I think line array designs should be excluded (and can generate much debate), but IMO bi-pole design (opposite facing, in-phase) should be OK.When "The One" came out I was skittish (low efficiency, limited power handling capacity, rather expensive), but the 1+1 takes care of my first two concerns and the even higher price is somewhat mitigated by its in-room suitability.Passive radiator(s) is/are the easy answer for crossover-less bass extension in a compact cabinet. The problem with passive radiators is that they are out of phase with the main driver, but at low enough frequencies shouldn't be much of an issue..Most audiophiles don't know what frequencies (or sound pressure levels) they're listening to. Frankly most single driver fans I know are really poor judges of frequencies (I suppose it's a self serving attribute), but I've seen it get to the point where they develop an actual distaste for 20 - 60 Hz.
The size of the single driver is, of course, paramount and the trade-offs of beaming versus lack of bass could be debated forever. I choose 8 inch drivers (no whizzer) which does provide excellent mid-bass coverage where so much "body" and music occurs and sacrificed high frequency dispersion. Even 2 or 3 way designs value a 6 or 7 inch driver for superior mid-bass and room filling response. Until I hear these speakers I'll withhold judgement on how well the passive radiators are integrated into the overall design, but I suspect that the very small cabinets combined with the drivers stated 12 mm travel limits help the passives work at lower sound pressure levels.
