SOLD! JVC RS1 Projector - Very Good Condition w/ Box / Remote / Manual - MD / VA / DC
0 Members and 1 Guest are viewing this topic. Read 1124 times.
jarcher
  • It Just Sounds Right
Have upgraded to a current model JVC DLA projector and looking for a new home for my RS1 (also known as the HD-1 and even clones from other manufacturers exist out there). Giving first purchase opportunity to AC members before going on other listing sites!
I've owned it for about 4 years and am the second owner (the former being a videophile who bought it from AVS science).  This is a serious home theater projector that initially retailed for over $5K when it first came out.  In many ways it still tops most new projectors under $1500 in terms of contrast ratio and picture / color quality. The lens shift (V & H) is also a very useful feature that is usually not found on projectors under $2K.  I'm asking for less than half that : $850.
For those not familiar w/ JVC's D-ILA technology, it's an LCOS panel : Liquid Crystal On Silicon.  In many ways it combines the best of LCD and DLP technologies, having the rich color and image depth of LCD, but also having the brightness and contrast ratios of DLP as a reflective technology without the use of mirrors and the dreaded "rainbow" effect.  It's primarily used by JVC projectors and Sony has a comparable tech called SXRD.  It's so well regarded that JVC D-LA and Sony XRD projectors consistently top the reviewers "best of" lists.
I have the original box, remote, and manual and it's always been ceiling mounted in a dedicated HT room and well taken care of.  I will also include an extra long heavy duty power cable.
Conditionally I'd give it an 8/10 for the following two reasons :
1) There are some light scratches on the top left of the case.  Not sure how that happened, but it's a glossy black surface.  In a darkened room obviously there's not much to notice.
2) With the aftermarket bulbs I've used it needs to be run in "high altitude" mode - i.e. faster fan mode - otherwise it trips the thermal sensor.  No damage occurs and you can restart in 10 minutes.  Running it in "high altitude" mode causes no thermal sensor trip and the fan is obviously running faster - but even having had it mounted 3 feet above my head, neither I nor anyone else has ever been bothered by the fan sound.  It is still substantially lower than the usual business presentation class projectors.
It's possible that OEM bulbs would not create this condition.  But as used and aftermarket bulbs cost less than $100, and new OEM bulbs over $300, you can appreciate why I - and likely you - would happily live with the slightly higher fan noise.  Bulb life is 2000hrs, but being a videophile and the bulb replacement cost being so low, I like to change at 1K hrs.  I've replaced the bulb only twice - so have put on average of about an hours use a day over the time I've owned it.
For these reason I'm asking below market price for this projector.
Some basic info :
- Native 1920 x 1080 resolution
- D-ILA™ New Three Chip technology
- 15,000: 1 High Contrast Ratio without using Iris by new optical engine (i.e. no noisy "dynamic iris" pumping to reach this contrast ratio)
- Outstanding Gray-scale reproduction
- Wide Lens Shift Range (V: 80%, H: 34%)
- Zoom Lens with 2 times Throw Ratio (1.4:1-2.8:1)
- Various Input Signals (2xHDMI, Composite, S-Video, Component)
- Low Fan Noise
- Sleek black cabinet with black non-reflective front panel
MD / DC / VA locals are welcome to inspect / demo the projector and buy / pick up.  For all others, shipping is available at my cost via insured Fedex (preferred), UPS, and USPostal.  I will consider overseas buyers, but order of preference is to local then USA buyers.
Please PM or Email me for any further questions or offers.  Please do not post such requests in this thread - it's counterproductive as emails / PM's reach me sooner anyway. If there's any important info I've left out, I'll update the listing.
« Last Edit: 17 Nov 2014, 03:27 am by jarcher »
jarcher
