0 Members and 1 Guest are viewing this topic. Read 6025 times.
Finally even after going to the expense of redesigning our circuit boards to "upgrade" all our signal path capacitors to polypropylene types, direct ABX testing of identical units with the original Mylar film capacitors against those with polypropylene capacitors yielded no audible differences at all. Darn!Regards,Frank Van Alstine
I think the OP is probably referring to a "shunt" configuration when referencing "bypass." This is one of those definitions that has been skewed greatly in meaning by the audiophile industry......and is not literally correct. Just FYI, the more correct, and original, definition of "bypass" is a capacitor used to bypass a resistor in an amplifier circuit to increase AC gain but not alter DC biasing. Examples would be seen in televisions, Ham radio gear, old audio amplifiers, etc, where a capacitor would be placed in "bypass" around the cathode biasing resistor in a vacuum tube stage. There some other examples in solid-state circuits as well.Cheers,Dave.
Except that shunt implies a direction of current change. The current doesn't change in the configuration of a signal bypass capacitor, as the end product is identical. I wouldn't call it a shunt unless it was an RIAA network or something else... Your original example does change the amount of current from one place to another, as you said to increase/maintain gain.
