Preamplifier Chassis for Tortuga LDR3x V2 kit
0 Members and 1 Guest are viewing this topic. Read 1860 times.
ClefChef
« on: 6 Nov 2014, 09:35 pm »
I had several chassis cut for the Tortuga kit. This chassis will fit LDR3x V2 board and two DM1 display modules plus rotary encoder, and that's basically all you need to build your own LDR preamp. The chassis comes with 3 input relay board and Nerve Audio RCA connectors, power plugs, dark grey plexiglass window, aluminum volume knob, USB cable, and relay input board connecting cable.
Chassis is all aluminum, front panel is CNC cut from 4mm black anodized aluminum, back panel is 2mm aluminum, engraved and in-filled with white paint. Chassis feet are anodized aluminum with rubber friction rings. There are standoffs for all Tortuga boards, just screw them in place.
The pics show assembled preamp, the boards and rotary encoder are not included.
$380.00 shipped within CONUS.
poseidonsvoice
    • 2 channel/7 channel setup
Re: Preamplifier Chassis for Tortuga LDR3x V2 kit
« Reply #1 on: 7 Nov 2014, 03:36 pm »
Good buy. Bump for a righteous dude! At this price you WILL NOT find a better volume control, period (even though you have to buy the rotary encoder, boards, etc...all the chassis work is DONE!!!). If your system is compatible, just buy the enclosure and add the parts! I already have a dual mono version I am planning on implementing into a differential (active) tube preamp or else ClefChef's unit would've long been sold  :thumb:
Best,
Anand.
