0 Members and 1 Guest are viewing this topic. Read 16493 times.
- budget $6-7k-ish, new or newer-used. Budgets are mere guidelines.Connected gear: both hi-res and redbook files fed from a CAPS Zuma SoTM server
- must be available for an in-home demo somehow.
Since my sole source is digital, then how about leaving out the preamp in favor of a DAC with a proper analog volume control? I don't need source selection, and can still mess around with NOS tubes in my Quicksilver Silver power amps. My source is a PCM/DSD library from JRiver on a micro Zuma SoTM CAPs. Selling my current SS preamp and PCM DAC will net around $7500, funds that can be recycled into a PCM/DSD DAC with a proper volume control. A potential candidate is the MSB Analog DAC, which does all this and potentially offers upgrade capacity. The volume control is 1db (78) stepped-attenuator. Thoughts? Suddenly in the wrong circle?
