Manic Moose on BDP-1
0 Members and 1 Guest are viewing this topic. Read 1666 times.
gustavog
« on: 3 Nov 2014, 10:44 pm »
Hi,
I am running Loony Tunes on my BDP-1. With all the lengthy beta test of the Manic Moose software I got lost. Is MM official? Does it run satisfactorily on a BDP-1? How do I get it to install on my BDP-1?
werd
Re: Manic Moose on BDP-1
« Reply #1 on: 3 Nov 2014, 10:53 pm »
It continually failed for me and I just got it. like 5 minutes ago. It was smooth and no issue crossover to MM
werd
gustavog
AVnerdguy
« Reply #4 on: 4 Nov 2014, 12:13 am »
Oh boy! Just what I need BUT unfortunately all I get is:
Error (404)
We can't find the page you're looking for. Check out our Help Center and forums for help, or head back to home.
I tried different browsers and modified string but no luck. Maybe if you went one page deeper and copied the link or tired a hyperlink? Can you please post again - please  :)
werd
« Reply #5 on: 4 Nov 2014, 01:04 am »
Try using the Firefox browser.
gustavog
« Reply #6 on: 4 Nov 2014, 01:30 am »
Same problem: Error 404 with Firefox
werd
« Reply #7 on: 4 Nov 2014, 02:11 pm »
Did you get it going yet?
gustavog
« Reply #8 on: 4 Nov 2014, 03:01 pm »
Nope. Perhaps Bryston (Chris) can barge in and clarify?
gdayton
werd
« Reply #10 on: 4 Nov 2014, 03:40 pm »
I wonder if this applies ?
http://en.m.wikipedia.org/wiki/HTTP_404
gustavog
werd
« Reply #12 on: 4 Nov 2014, 03:57 pm »
Oh man I feel bad. I thought the update was the error. I should've checked the link. It's the link I used and it worked and probably didn't get copied right.
AVnerdguy
« Reply #13 on: 4 Nov 2014, 05:03 pm »
NP. Excellent. Thank you! Just what was needed. Been meaning to update forever but was afraid of getting in the middle and getting blowed up real good. This is almost too easy  :D
gustavog
« Reply #14 on: 4 Nov 2014, 05:44 pm »
Thanks to all! The upgrade was a breeze :-) Running MM now on my BDP-1
werd
« Reply #15 on: 4 Nov 2014, 05:53 pm »
That's good news since we all went at it at the same time  :thumb: This MM takes it up a few notches. Don't know what it does but seems to drive the dac way better. More resolution better beats. Wakes up.
