0 Members and 1 Guest are viewing this topic. Read 27825 times.
It's pretty amazing and could probably go up against many DACs in the under $5k range. I also had an Auralic Vega DAC ($3500) to test and the Sony is just as good. My system is single ended and the Vega will sound better balanced so if you convert the Vega's balanced to single ended using a trafo you'll get better results but now it's 2x+ the cost of the Sony, a computer and USB cable are still required. It's pretty hard to fault the Sony in any way except when I first got it it had a very accurate SS sound, not in a bad way, but the last couple firmware upgrades have made it sound very natural and more relaxed... it's hard to tell what the output stage is now, could be a very good tube or SS, you wouldn't know until you look. It's dual mono and the separation and imaging are far better then the Bifrost it replaced, the Sony makes the Omegas throw a huge soundstage and imaging is very precise. I think the last firmware upgrades are providing a similar sound to the tube output stages developed by Red Wine and Modwright, at first I could see using a tube output stage but now it's very close to perfect and i have no plans to upgrade it at all.
I just got a nice demo Jolida Glass FX Dac III today and so far I'm loving it's sound. I've got it running from my macbook pro to my Miniwatt N3 (still waiting for my new amp to come in) to my 3U and it sounds amazing. It takes 2 12ax7 tubes, mine came with Russian Re-Issue Tung-Sols, so I'll after I get used to its sound and let it break in a little I'll report back when I roll the tubes. I'm thinking either some NOS Telefunken or new Psvanes.
MHDT Pagoda is an interesting nos dac based on the BB 1704 I used to own the Havana before obtaining the Metrum Octave (which I still own). Recently dropped in a pair of Jupiter Coppers.. Very sweetYMMVDwight
My ultimate criteria for any DAC is how close it comes to a good vinyl rig, and how well it does 16/44. Don't think I disregard higher resolutions as I know generally they sound better than 16/44. However, many hi-rez DACs don't do 16/44 as well as a good dedicated NOS DAC like the Audio Sector. The OP started this thread entitled "DAC recommendations/experiences with Omega Loudspeakers". I personally believe more care should be taken when choosing a DAC (or any upline equipment) when pairing it with Omega speakers because of their transparent nature and ability to reveal everything upline, and not gloss it over.In relation to Omega Speakers, some of my favorite DACs are: Audio Sector USB, Resonessence LAB Concero HD USB, and KingRex UD01 USB with PSU MK2. In the more affordable category: Audioengine D1, and Glow Audio DAC V1.3.The KingRex UD384 with UPower battery is also incredible, but I heard it on a very good solid state, non Omega system.The Resonessence Labs Herus+ has only been played briefly in my main system but what I heard sounded great, so I'll not comment on it other than to say it's super with the IEMs I tried with it.Salis Audio brought up a very important subject concerning good sound in a DAC, and that's how it's powered. The Audio Sector, KingRex UD01, and KingRex UD384 with UPower are all self powered with high quality power supplies and are all incredible sounding.Does that mean the others don't sound good because they're USB buss powered? No, not at all. The Concero HD is one of the best DACs I've heard, but I think separate clean power would take it to the next level, ditto the other USB powered DACs on my list.The answer is to split the USB cable 5V buss from its digital side and feed separate clean power through the 5V buss side. There are three options that I know of: iFi iUSBPower USB power conditioner, batteries like the KingRex UPower and Bacoon BPS-02, or a 5V power supply like the Aqvox.
Has anyone heard the PS Audio DirectStream DAC with Omegas (or any speakers)? Expen$ive as-all-get-out but owners of it say it is almost the last word in extracting detail from 44/16 material. It upsamples PCM to 10xDSD then downsamples to 2xDSD before a simple passive output filter. I've been talking with the designer who is convinced of DSD's intrinsic natural sound quality.
I've been thinking about getting a DAC to use for computer based playback. My trouble is I'm not even sure what I'd want. I've owned two 1543 DAC's, Peter Daniels (not the PTTL). They're still so much better than things in the price range it's silly. But Blackgate caps folded, and there's no PCB's. The fact they don't take any hi-res isn't a bad thing sonically, but bad for those that own hi-res media.I guess the question is, do I need to develop one? I've got plans for a DSD device, but I haven't started, and would have to upscale everything to DSD for playback. It's actually somewhat frustrating looking for a DIY DAC that's in the world class status like the PD units. As far as buying one I'm not ready to spend spend $3500 or better on something I'll probably have to tear apart to satisfy me.
IMO, the Sony HAP is the way to go unless you have $4k+, I've tried lots of cheaper DACs and the Sony is in another league, about as good as an Auralic Vega.
There's so much development in DACs that I have to wonder how much of the early posts is still relevant.
