HT3 speaker terminals
0 Members and 1 Guest are viewing this topic. Read 1372 times.
vkohl
« on: 31 Oct 2014, 08:23 am »
The rear of the 2009 HT3. i see 2 pair of terminals. When using "jumpers" which pair of terminals do most of you use? The top pair? [high/mid i assume?] OR the lower pair? [woofer i assume?] ---- thanks for your opinion.
martyo
Re: HT3 speaker terminals
« Reply #1 on: 31 Oct 2014, 09:08 am »
I bi-wire now but before I did I used the bottom terminals. And your assumptions are correct.
TJHUB
« Reply #2 on: 31 Oct 2014, 11:24 am »
A few of us Salk owners have found out the Cardas copper jumpers supplied deteriorate over time, and really negatively affect the sound.  We have all since switched to bi-wiring, or in my case, I had my speaker cables made with jumpers built in.
If you have jumpers that have deteriorated, it's best to use the top terminals as the mid/high frequencies are more easily negatively affected.  I have found treble to be most sensitive to anything metal in cables, jumpers, connectors, so I always keep the path to the tweeters as simple as possible.  I always use the top terminals first.
Big Red Machine
« Reply #3 on: 31 Oct 2014, 11:39 am »
+1
