Shareplay on BDP-2
0 Members and 1 Guest are viewing this topic. Read 1242 times.
Slanski62
Shareplay on BDP-2
« on: 30 Oct 2014, 10:20 pm »
Can anyone explain the secret to Shareplay?  In MM settings, I have it checked and it says ready.  On my iDevice, I'm playing pandora.  I have the output set to airplay to device BDP:00:03:2d:1f:f4:e4.  There's no audio coming from my iDevice, but the BDP-2 is silent also.  What could I be missing?  Thanks for any help.
unincognito
    • bryston.com
Re: Shareplay on BDP-2
« Reply #1 on: 30 Oct 2014, 10:45 pm »
Are you using a USB DAC?
Cheers
Chris
Slanski62
« Reply #2 on: 30 Oct 2014, 11:09 pm »
Yes I'm using a psaudio direct stream via USB
unincognito
    • bryston.com
« Reply #3 on: 2 Nov 2014, 01:02 am »
That would be why, this feature only outputs via AES/EBU and bnc.  We have yet to update the firmware for USB, it is coming with the release of the BDP-1USB.
Cheers
Chris
yyz
« Reply #4 on: 2 Nov 2014, 04:59 am »
So the BDP-1USB will work with the PS Audio DS? I am getting the DS and was thinking the BDP-1USB or a CAPS Zuma PC.
Linux vs Windows Server 12 with AO.
unincognito
    • bryston.com
« Reply #5 on: 6 Nov 2014, 04:50 pm »
We havn't tested one, but it appears to be a standard class 2 USB Audio device and should work.
Chris
