60hz hummmm
0 Members and 1 Guest are viewing this topic. Read 912 times.
harley52
60hz hummmm
« on: 30 Oct 2014, 09:18 pm »
I'm new when it comes to receivers. :duh: :scratch: Not new to 2 channel. Anyway, when I plug in that hdmi cable from tv to the rec. I get a big dose of 60hz hum. I'm using a separate amp to power the speakers. I been lucky I guess but only ran into 60hz hum about 100 yrs ago. Any help would be appreciated.
JRace
  • Greetings one and Everyone!
Re: 60hz hummmm
« Reply #1 on: 30 Oct 2014, 09:22 pm »
Unplug the CATV line and see if it goes away...
if so your Cable TV line is not properly grounded.
Gzerro
Re: 60hz hummmm
« Reply #2 on: 30 Oct 2014, 09:44 pm »
Your cable tv coax cable isn't grounded properly.
If tracking down the source of the ground loop fails, one of these guys will fix it:
http://www.amazon.com/Viewsonics-VSIS-EU-Cable-Ground-Isolator/dp/B0017I3K9M/ref=sr_1_12?ie=UTF8&qid=1414705266&sr=8-12&keywords=ground+hum+eliminator
harley52
Re: 60hz hummmm
« Reply #3 on: 31 Oct 2014, 01:47 am »
Well, that's simple enough. Thanks guys
