0 Members and 1 Guest are viewing this topic. Read 4312 times.
Nice. thank you.btw. did audio research, conrad johnson, sim audio, pass, or any other big names ever make a phone pre amp with volume control?seems that it would be a desired feature for turntable enthusiasts.thanks again.
If a get a top notch Phono Pre Amp and Amplifier, and I can skip a Standard Preamplifier to hook up my Phono Pre Amp into, as I will only be using this setup for records?If this is possible any suggestions for a top tier phono pre amp with volume control?thank you.
Is there a design reason why most phono pre amps do not have a volume control, as to skip a standard pre amp in a TT setup?
After performing the "Bolero Test" as detailed by Arthur Salvatore, I discovered that my Parasound JC3 phono stage was capable of driving my Audio Mirror SET 45 monoblock power amps. If you do this at home, just be careful not to blow out your speakers or your ears for that matter. Based on this test, I decided to get a passive line stage to control volume. The results are really fantastic, and I have no need for an active preamp.
