SPEAKER SWITCH BOX
0 Members and 1 Guest are viewing this topic. Read 1078 times.
tvyankee
SPEAKER SWITCH BOX
« on: 9 Sep 2004, 07:18 pm »
LOOKING TO FIND SOMEONE WHO MAKES A AUDIOPHILE GRADE SPEAKER SWITCH BOX SO I CAN SWITCH BETWEEN TWO AMPS.
I GUESS IT WOULD NEED 2 INPUTS FOR THE AMPS AND 1 OUTPUT SO I CAN USE THE SAME SPEAKERS WITH TWO DIFFERENT AMPS.
I WANT SWITCH BETWEEN MY HOME THEATER RIG AND MY TWO CH RIG.
ITS BECOMING A PAIN IN THE ASS CHANGING CABLES BACK AND FORTH.
I DON'T KNOW IF ITS WORTH IT BUT IT WOULD BE NICE NOT TO HAVE TO CHANGE MY CABLES BACK AND FORTH.
THANKS.
JoshK
SPEAKER SWITCH BOX
« Reply #1 on: 9 Sep 2004, 08:04 pm »
I think the switch after the preamp for choosing which amp wouldn't be a big deal at all to do.  Hell I can probably make you a good one for little $.  The problem I see is which the switch box at the speaker cable level.  This could be problematic and deterious. I might be inclined to terminate my speaker cables with bananas so that it is easy to swap speaker cables for choosing which amp.
Jeff Aguilar
SPEAKER SWITCH BOX
« Reply #2 on: 10 Sep 2004, 09:22 pm »
I am using the Niles DPS-1 for that.  I have both solid state amps for movies and tube amps for music.  This way I can hook both amps to one set of speakers.
Jeff Aguilar
  • Speakers....What Speakers ?
SPEAKER SWITCH BOX
« Reply #3 on: 12 Sep 2004, 01:15 pm »
tvyankee,
    Spotted this on Audiogon....
Niles Switching System. Useful ??? :) [/list:u]
