Cyclops | Dac´s Line out output voltage - Any impact??
0 Members and 1 Guest are viewing this topic. Read 1315 times.
marflao
Dear all,
I need some help on the following topic: I´m in the market for a new Dac and I stumbled over the RCA Line out output voltages.
One DAC´s specs mention a value of 2Vrms max variable and another Dac has 4Vrms max variable. Line out output impedance is the same with both DACs (47Ohm).
Will their be a negative/positive impact if I choose the DAC with the lower/higher value? Or will it be irrelevant and the Cyclops plays well with any DACs regardless their line out output voltages???
Many thanks in advance.
M.
P.S. I already dropped Klaus an email but he obviously too busy to answer my noob question ;-)
Therefore I thought this would be the right place here to get some feedback  :thumb:
firedog
Re: Cyclops | Dac´s Line out output voltage - Any impact??
« Reply #1 on: 22 Oct 2014, 11:08 am »
It shouldn't matter. 2V is considered standard for devices like a CD player, but 4V is common. My Kismet amp does okay with a DAC putting out 6V.
For some amps this might be overload, not for Klaus'.
marflao
« Reply #2 on: 22 Oct 2014, 12:09 pm »
Great. That´s what I hoped to hear ;-)
Many thanks for your swift response, firedog!!!
