0 Members and 1 Guest are viewing this topic. Read 19614 times.
If you are going to invest in a set of Heil AMT's and plan to cross that high, take a look at some of the LF Altec Lansing drivers reworked by Great Plains Audio. Your woofers will be reproducing some very critical fundamentals and you will want something that is very articulate to match the speed and clarity. http://www.greatplainsaudio.com/woofers.htmlAs an alternative, you may want to contemplate a 3-way design, using a small midrange coupler between the LF and HF sections. The Hestia V is an example which uses the Dayton AMT and a mid-coupler, albeit crossed much higher.
Matevana,where would you think the best place would be, to cross over the Heil AMT's ?
Wild Burro Audio Betsy 8" with bass help?http://www.randallrash.com/New_Loudspeakers_part9.htmlhttp://www.wildburroaudio.com/speakers.php
That is exactly what I did. Altec 416s reworked by GPA.I cross 1st order @ 1,000Hz on the woofers, 3rd order @ 1,200Hz to the Heils.Big cabinets ~10 cu/ft made of Baltic Birch plywoodEdit: Sorry, didn't realize this is the OB forum.
You are going to need a mid bass coupler of some sort. There is going to be too big of a frequency hole between the Heil and the Alpha. Just for grins, take a look at Ed Schilling's Horns. He uses a Fostex for the mid bass. The AMT is series wired to the mid. I know this combo works well. All you would have to do is figure out where to bring in the Alphas. A starting point anyway.[/quoteWhere do I go to see Ed Shillings horns ?
I, who has owned a pr. of the original ESS heil units for 30+ years and I'm still using them. I don'tbuy Ed S. advise as to what they can handle as far as X-over points. I use them in a active/ triampsystem crossed at 1000hz/18db and have never melted them. Don't know where he is coming up with his numbers.
I never stayed with my various OBs because I couldn't get the detail I wanted with compression drivers. However, I have been listening to Heil AMTs crossed over at 24 db/octave at 1 K and these are truly amazing dipole tweets.So, I am thinking about an AMT based OB with either 2 15 Alphas crossed at 1K or two 12s. 12s might work better crossed that high. Any recs on a pair of 12s that give you that magic live OB sound and are clean to 1 kHz? I like and have used the Alphas but I already have two subs (ML sealed) and thinking that maybe there is something better to mate with the AMTs. Or twin Betsy's??TIA
