Super V A370PEQ settings
0 Members and 1 Guest are viewing this topic. Read 1554 times.
Trismos
« on: 20 Oct 2014, 12:18 am »
Hi
Can someone steer me to a post or two on setting up the A370PEQ for the Super-V please?
I've done a couple of searches but am not getting lucky.
Thx
Dave
Re: Super V A370PEQ settings
« Reply #1 on: 20 Oct 2014, 12:49 am »
dragoonxp20
« Reply #2 on: 20 Oct 2014, 02:48 am »
You want to first match the level to the amp powering the coaxials. Do this by adjusting the gain so the overall sound is balanced. (Microphone and roomeqwizard helps here)
Set the crossover point somewhere between 80hz and 100hz. It doesn't have to be exact. You can play around with it later.
The phase should be set to 180 degrees. Don't need to mess with that at all.
Extension and damping are just personal preference and you can use the eq to take care of peaky bass.
Trismos
« Reply #3 on: 20 Oct 2014, 02:53 am »
Thanks guys!
