Headless Mac Mini running Mavericks with super slow performance? Read on....
dburna
For far too long I have suffered trying to run a headless Mac Mini under Mavericks with absolutely p*** poor latency and slow performance.  It was nearly unusable.  I finally stumbled on on this solution et voila....problem solved.  This is ridiculous to have to implement this kludge -- Apple should fix this problem immediately -- but since they haven't, this fix works.  If you are having the same problem I was, you may benefit from the following:
http://www.tristanbettany.com/2013/06/17/slow-screen-sharing-in-osx-vnc-performance-issues/
Cheers.....and happy listening (unimpeded by a sluggish Mac Mini),
-dB
