***SOLD***: Blue Circle PLC Thingee Power Conditioner
0 Members and 1 Guest are viewing this topic. Read 658 times.
Early B.
***SOLD***
For sale is a 6-outlet Blue Circle PLC Thingee in great condition. The PLC Thingee is a non-current limiting power conditioner; high current power amps can be plugged into it without losing dynamics. The PLC Thingee features industrial grade Hubbell outlets, and a thick wall $” ABS pipe for durable construction and strength. The lower noise floor is impressive and belies the PLC’s aesthetics.
A double run of 14 awg solid copper wire between filters is used, and the power inlet is directly soldered onto the copper wires. The power path is extremely short which further minimizes resistance. With the silicone filled 4" ABS pipe, the Thingee is very strong. It can be installed behind any equipment rack. Dimensions are 4.5” diag x 4.25 long.
« Last Edit: 18 Oct 2014, 09:46 pm by Early B. »
