More Smoke!
0 Members and 1 Guest are viewing this topic. Read 1472 times.
Julien43
More Smoke!
« on: 8 Sep 2004, 10:44 pm »
I replaced the opamps(right way this time) and 220uf 'lytics,  connected the batteries and this time the other 'lytic smoked. This time I checked to make sure the SLA's were marked correctlly.  :banghead:
Steve Eddy
    • http://www.q-audio.com
Re: More Smoke!
« Reply #1 on: 8 Sep 2004, 10:58 pm »
Quote from: Julien43
Ouch!
Perhaps use some non-polar electrolytics? :?
se
Julien43
Dumb Ass!!!!! Problem solved
« Reply #2 on: 9 Sep 2004, 09:12 pm »
I, obviouslly had been connecting one of the SLAs reversed. I replaced the second electrolytic, double checked the DC input wiring and no more burnt caps, Just sweet music :D  I was wondering, could someone tell me the best way to connect a led to indicate Power Up? Thanks for putting up with my moronic post
hagtech
More Smoke!
« Reply #3 on: 10 Sep 2004, 05:32 pm »
With two batteries, I like to run the LED between them.  Wire an LED in series with a 2k or so resisor between supplies.  See my power supply schematic for reference.
Glad to hear you're up and running!
jh :)
