SOLD!! - Conrad Johnson Premier 11A - 70wpc stereo power amplifier
0 Members and 1 Guest are viewing this topic. Read 8685 times.
pstrisik
  • Holding pattern in Audio Nirvana in the PNW!
Conrad-Johnson Premier 11A Amplifier
Excellent working condition.  Excellent cosmetic condition save minor ding on front lower right corner, minor paint surface scratch on right side - no other flaws.  These can be seen in the photos. Complete with tube cage, vintage RCA 5151's, vintage 6CG7's, KT120 power tubes all with ~500 hours, original bound manual, biasing screwdriver, four spare fuses, and new factory box with inserts.  $1950 $1875 $1795 (likely last price reduction) plus 85% of shipping.  Original MSRP $3500 in 1990's dollars.
In my opinion, this is the sweet spot in the Conrad-Johnson timeline 1993-2000.  On the cusp between very warm and softer earlier models and more neutral later models, the 11A has just the right about of midrange warmth.  You can either run KT88, KT90, 6550 or KT120 power tubes.  KT120's are included and are what C-J now endorses for the best sound.  Note that these newer tubes are taller than the original 6550's.  Therefore the tube cage would have to be lifted slightly to accommodate the height.  I preferred to keep the amp displayed without the cage.  It really looks designed to be displayed open where you can see the anodized gold top, bank of transformers at the rear and the fully glory of the tube glow!  This is the Pr11A, the later version with noise reduction incorporated.  The original model was the Pr11.  As the name implies, C-J gave the Premier models the best quality parts.  It was manufactured in 1997.
Insured shipping by either Fed-ex Home Delivery or Second Day.  My actual insured shipping cost less 15% since I'm shipping from Alaska.  Box is 22 x 21 x 14 and 69 lbs.  Paypal family and friends or money order, bank check after clearing.  Regular Paypal adds 3%.
I'm happy to answer questions if I can.
Tubes:
Four Tung-Sol KT120 (also compatible with 6550, KT88, KT90)
Two 5751
Two 6FQ7/6CG7
Manufacturer's product page:
http://conradjohnson.com/It_just_sounds_right/a-pr11.html
Stereophile Review:
http://www.stereophile.com/tubepoweramps/403/
Specifications:
Power Output ­ 70 watts per channel RMS at 4, 8, or16 ohms both channels driven from 30Hz to 15kHz with no more than 1% THD or IMD.
Response: 20Hz to 20 kHz, +0, -.1 dB
Input Sensitivity: 0.9 volts to rated power
Hum & Noise: 96 dB below rated power
Mechanical: 17" x 7" X 15"
Weight: 54 lbs.
« Last Edit: 28 Nov 2014, 05:36 pm by pstrisik »
pstrisik
Some inquiries, but still available.  Not seeing these come up very often any longer.  There is currently one on ebay for the same price.
pstrisik
Bump.
pstrisik
Price reduction.
pstrisik
(Likely the last) price reduction!
Happy Thanksgiving to those in the US!
pstrisik
SOLD!
