Paradigm Studio 20, version 5 speakers in like new condition -- SOLD!
0 Members and 1 Guest are viewing this topic. Read 978 times.
diofan56
I'm relisting my speakers because the deal with the guy in Canada fell through.  Basically it's because shipping costs to Canada are horribly expensive and neither of us wanted to spend an extra hundred bucks.  I compliment him; he has been very understanding about the whole situation.
Paradigm Studio 20 speakers, version 5, cherry veneers.  I'm the original owner; I bought them in 2013.  The speakers have been used but NOT abused.  They are in like new condition.
From the Paradigm web site:
G-PAL™ Gold-Anodized Pure-Aluminum Domes. Exceptionally rigid low-mass domes with treated textile suspensions ensure remarkably uniform and instantaneous power response. The elevated position of the dome provides better ‘air’ and frequency response that is smooth, pure and clear.
S-PAL™ Satin-Anodized Pure-Aluminum Midrange and Bass / Midrange Cones. Very high stiffness-to-mass ratio and outstanding internal damping. The result? Remarkable midrange clarity, superb extended bass response and freedom from unwanted resonances and distortions.
IMS/SHOCK-MOUNT™ Isolation Mounting System. This unique butyl-rubber driver fastening system found on all Studio Series drivers is a progressive system of critically placed isolation inserts and gaskets that decouple drivers from the speaker enclosure itself. This leading-edge ‘baffle-less’ technology reduces driver / enclosure interactions to inaudible levels.
High-Velocity Low-Noise Aluminum Ports. Bass efficiency and minimum turbulence distortion for cleaner and more articulate bass response.
Beautifully Sculpted Cabinets with Real Wood Veneer Finishes. Add a whole new dimension to the classic appeal of this series. Seven coats of the highest quality lacquer, hand-sanded between coats. Available in four luxurious real wood veneer finishes.
Design:  2-driver, 2-way bookshelf / stand-mounted
Crossover:  2nd-order electro-acoustic at 2.0 kHz
Frequency Response   On-Axis:  ±2dB from 54 Hz - 22 kHz
Frequency Response   30° Off-Axis:  ±2dB from 54 Hz - 20 kHz
High Frequency Driver:  25-mm (1 in) G-PAL™ dome, ferro-fluid damped / cooled, die-cast heatsink                      chassis, IMS/SHOCK-MOUNT™
Mid/Bass Frequency Driver:  178-mm (7 in) S-PAL™ cone, 38-mm (1-1/2 in) voice-coil, AVS™ die-cast                      heatsink chassis, IMS/SHOCK-MOUNT™
Low Frequency Extension:  36 Hz (DIN)
Sensitivity:  Room / Anechoic  90 dB / 87 dB
Impedance   :  Compatible with 8 ohms
Suitable Amplifier Power Range:  15 - 180 watts
Maximum Input Power:  110 watts
Finishes:  Cherry, Rosenut, Black
Weight:  24 lbs. (10.7 kg)
Dimensions   HxWxD:  14.625" × 8.875" × 13.125"  (37.2cm × 22.5cm × 33.5cm)
The original packaging and manuals are included.
MSRP is $749.00 each.  I'll let the pair go for $800.00.  That price includes shipping within the continental United States, insurance, and PayPal fees.
I won't ship the speakers internationally because the shipping costs are too high.
« Last Edit: 27 Oct 2014, 11:28 pm by diofan56 »
diofan56
Re: Paradigm Studio 20, version 5 speakers in like new condition
« Reply #1 on: 25 Oct 2014, 02:30 am »
Bump...
