NHT SA-3 Subwoofer Amplifier
0 Members and 1 Guest are viewing this topic. Read 3794 times.
sharper
« on: 8 Sep 2004, 02:28 am »
Has anyone tried driving a VMPS sub with an NHT SA-3 sub amplifier ?
I know the other NHT sub amps (e.g., SA-2) are supposed to lack power and not be that great...but the SA-3 looks like it may be alright.
Housteau
« Reply #1 on: 10 Sep 2004, 09:26 pm »
I am not familiar with the NHT.  However, I have recently had an eye openning experience regarding amps for bass and sub-bass extension.
I think that there are very few absolutes in Hi End audio.  Most are very system dependant and this may be one of them.  Over the years I have had several friends try different amplifiers for bass in biamped systems.  These systems are similar in that they involve the larger Infinity line source arrays of bass drivers in seperate towers.
I have always used the venerable line of Bryston ampifiers on bass and have never looked back, until just recently.  My friends have also tried Bryston along with just about every respected brand of amp known for it's controll of those lower regions.  Were talking top of the line Krell, Mark Levinson etc.  Long ago they settled on the mightly, but more slight John Iverson Eagle IIa for it's superior control on those Infinity towers.  Over the years they tried trying to tell me what I was missing, but I was quite content with my Bryston and quite pleased with my low end performance.
Well, finally I gave in and picked up an old Eagle IIa for around $350.  I installed it in my system and was instantly floored at the transformation.  It was not a small change, but quite substantial.  From this less efficient amplifier I am getting more apparent bass that is tighter, more well defined and has such an iron clad grip on my bass towers that it must be experienced to be believed.
I guess what I am saying is that if you are looking for not only a good amp for a subwoofer, but one that may actually be one of the very best available, period, then it would be worth your while to seek out some used Hi Fi sites for an Eagle IIa.  The passing years and technological improvements do not seem to have improved upon it's bass performance.
RGordonpf
« Reply #2 on: 10 Sep 2004, 10:55 pm »
I second Housteau's comments regarding Eagle amps.
I use a pair of Eagle 400 monoblocks to drive my dual voice coil VMPS Larger subwoofer.  It is probably over kill - 400 watts per channel, but the bass is everything you ever wanted.  The John Iverson designed Eagle (Electron Kinetics) amps have quite a cult following and for good reason.
You can still get Eagle amps serviced and upgraded by one of John Iverson's key tech people at www.eagle-audio.com.
sharper
« Reply #3 on: 15 Sep 2004, 05:35 pm »
Thanks for the responses. That's good advice and a good reminder. You really do need/want that kind of power and control to get the most from VMPS woofers. I used to have an ARC D350 (350W SS) powering my VMPS Tower II/R's and the bass was phenomenal. I'm sure the NHT would not have cut it with my NOS.
