0 Members and 1 Guest are viewing this topic. Read 2068 times.
I just wanted to caution any of you who use Blue Tack to hold your surrounds on your stands. I use 3 one inch strips in a triangle pattern and when I removed one of the speakers from the stand one of the strips pulled the vener off with it. I'm not sure why this happened, I have removed the speakers once before during my last move without incident.Jim,Coenceadently enough I'm moving to Denver on Monday and was planning on attending RMAF. Can I give you the speaker to take back with you for repair?Scott
when I remove speakers from stands than have blue tack on the bottom, I work a long piece of dental floss between the speakers and the stands to try and loosen-up the blue tack.
