Bryston 7B-ST warranty and voltage conversion (for JT)
0 Members and 1 Guest are viewing this topic. Read 1170 times.
dogbait
Mainly to James.
I own the PMC modified 7B-ST amplifiers as listed here:
http://www.audiocircle.com/index.php?topic=92570.msg944552#msg944552
Wanted to know whether it's worth bringing these amps from the UK to the US when moving.
1. Would Bryston support these PMC branded amps (I believe PMC modify them by removing the clip sensing circuit)?
2. How much would it cost to convert the amps to 110V?
thanks!
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston 7B-ST warranty and voltage conversion (for JT)
« Reply #1 on: 5 Oct 2014, 04:34 pm »
Hi
Yes we will honour the warranty if you are bringing them into the country with you.  Email Mike Pickett on the pricing please - [email protected]
james
dogbait
« Reply #2 on: 6 Oct 2014, 09:51 am »
Thanks, will do.
