SOLD : Rotel RA-1062 integrated amp with remote. VERY clean. $225 + ship.
0 Members and 1 Guest are viewing this topic. Read 1310 times.
RDavidson
For sale is my well reviewed, black, Rotel RA-1062 integrated amp. It is super clean and in pristine condition EXCEPT for a ding on the edge of the source selector knob. If not for the ding, it would be an easy 9/10, but I'll rate it an appropriate 7/10. I bought this amp on a whim about a year ago and it has sat in its packaging in a closet most of the time. I came across it during a buying frenzy and just couldn't resist. This is the 3rd time I've owned this model. It's just a fun, punchy, lively, and versatile piece of gear. It doesn't get the use it should and I really need to let it go to someone who will enjoy it. At this price, just give it a try. I think you'll be surprised. It even has a pretty nice phono stage. I'll try to post pics soon if it doesn't sell quick.
Model RA-1062
Watts/Channel all channels driven, unbridged, 8 ohm load
2 x 60 watts
Total Harmonic Distortion
(20 Hz - 20 kHz)   <0.03%
Intermodulation Distortion (rated power)
0.03% max
Damping Factor (8 ohms)   150
Phono Input   20Hz - 15kHz, ± 0.2dB
Line Level Input   10Hz-100kHz, +1, -3dB
Line Input Sensitivity   160mV / 24kOhms
Bass   +3, +4dB at 100Hz
Treble   +3dB at 10kHz
Line Input Overload   5V
Phono (MM)   2.4mV / 47kOhms
Phono Overload (MM)   170mV
Preamp Output Levels / Output Impedance   1V / 470 Ohms
Signal to Noise Ratio (IHF A)   >95dB
Power Requirements USA   115 Volts, 60Hz
Power Requirements CE   230 Volts, 50Hz
Power Consumption   300 watts
Dimensions (W x H x D) mm   432 x 92 x 364 mm
Dimensions (W x H x D) in   17 1/8 x 3 5/8 x 13 5/16 in
Front Panel Height   80mm, 3 3/16 in
Weight (net)   7.8 kg, 17.2 lbs
Asking $225 plus shipping from 57006
Paypal preferred. I'll incur the fee. :thumb:
« Last Edit: 30 Oct 2014, 02:30 am by RDavidson »
RDavidson
Bump. Will try to post pics soon. I'll consider interesting trades too. Let me know what you have.
« Last Edit: 10 Oct 2014, 01:39 pm by RDavidson »
RDavidson
Bump. Offers? Trades?
Pics to come.
RDavidson
Here are a few OK pics I took awhile back that I forgot I had. I'll try to take some better ones, including close ups.
