Resistor in signal path
0 Members and 1 Guest are viewing this topic. Read 1895 times.
bart11073
« on: 19 Feb 2003, 04:01 pm »
Hi,
Ik have a CD-player with a variable output but it is way too high. Only the lower part of the volume is usable. So I was thinking of putting some resistors in the signal path after the CD-player. What resistor should I use and how much resistance?
Bart
Vinnie R.
    • http://www.vinnierossi.com
Re: Resistor in signal path
« Reply #1 on: 19 Feb 2003, 09:38 pm »
Bart[/quote]
Bart,
This link will be most helpful:
http://www.goldpt.com/pre.html
This requires two resistors, and is a simple circuit
known as a voltage divider.  The link gives you
resistor value choices based on how much attenuation
you are looking for.
Good luck,
Vinnie
