SOLD: Cary SA-500.1 Mono Blocks - Black - Price Reduced
0 Members and 1 Guest are viewing this topic. Read 2582 times.
dminches
For sale is my pair of Cary SA-500.1 mono blocks amps, in black, in excellent condition. I am the original owner.
Asking price $old.
These amps will drive any speakers with ease. I used them with my Vandersteen 5As which require a good amount of power.
Each SA-500.1 is rated at 500 watts per channel into 8 ohms and 1000 wpc into 4 ohms. The amps can be used with either an unbalanced (RCA) or balanced (XLR) pre-amp. Each amp also features a trigger for each on and off.
Other than a couple minor scuffs the amps are in great physical condition.
Buyer pays for shipping. I will cover the paypal fees.
Specs:
Circuit TypeSolid State, Class A/BPower Output1 x 500 watts @ 8 Ohms
from 20Hz to 20KHz, 1 x 1000 watts @ 4 Ohms
from 20Hz to 20KHzFrequency Response10Hz – 50KHz +/- 0.1 dBSignal-to-Noise Ratio>100dB, “A” WeightedInput Impedance30K Ohms RCA-unbalanced
30K Ohms – Balanced (XLR)Voltage Gain28 dBAC Power Requirements117/234 Volts AC @ 50/60 HzBreak-In Time100 hours of playing timeAudio Input1 RCA, 1 XLRAudio Output1 pair Heavy-duty, gold-plated binding postsTHDLess than 0.05% at rated outputDamping FactorGreater than 400 from 10Hz to 400HzRemote Trigger3.3-24v DC at 5mA or greaterFinishBlack epoxy coated steel chassis
Weight: 65 lbs
Dimensions 7” H x 17.7”W x 19.5 ”D
« Last Edit: 8 Dec 2014, 02:06 am by dminches »
Phil
Re: Cary SA-500.1 Mono Blocks - Black
« Reply #1 on: 27 Sep 2014, 06:33 pm »
I don't know anything about the amps, but can vouch for the seller.  Having purchased from him, I can say that he keeps his gear in beautiful condition, is very fair on price and is great to work with.
Good luck with the sale.
Phil
dminches
« Reply #2 on: 27 Sep 2014, 07:10 pm »
Thanks Phil. Someone will be getting a really nice pair of amps. These things sound great and are powerful.
dminches
Re: Cary SA-500.1 Mono Blocks - Black - Price Reduced
« Reply #3 on: 25 Oct 2014, 09:56 pm »
Bump
dminches
« Reply #4 on: 9 Nov 2014, 10:20 pm »
Bump
dminches
« Reply #5 on: 21 Nov 2014, 06:45 pm »
Bump
