New affordable PSU
0 Members and 1 Guest are viewing this topic. Read 2184 times.
ebuzz
New affordable PSU
« on: 25 Sep 2014, 07:41 pm »
Someone has finally made an affordable power supply that I'd like to try.  Its much less than the Walker or the VPI model at < $300
 http://www.phoenix-engr.com/#!/
The unit will only work with AC motors using no more than 5 or fewer Watts,  however.
It's very frustrating trying to get specs on my older WT square motor table being that it's no longer in production and WT isn't much help either.
Does anyone know or is there a way to determine if those square motors are <5W
rollypolly
Re: New affordable PSU
« Reply #1 on: 28 Oct 2014, 10:58 pm »
I'm measuring 6W on my square motor using a watt meter. House voltage was measured at 122V and the motor was consuming 0.05A.
Hope it helps!
Rolly
ebuzz
« Reply #2 on: 19 Nov 2014, 09:17 pm »
Thanks Rolly,
Finally able to measure mine and it was closer to 7 watts.  Can't use that PSU
xsb7244
« Reply #3 on: 24 Nov 2014, 08:55 pm »
ebuzz
« Reply #4 on: 2 Dec 2014, 03:02 pm »
I'd definitely be interested if it will work with my motor.
