Dish Network with Oppo 103d
0 Members and 1 Guest are viewing this topic. Read 936 times.
rklein
  • My finest audio piece ever!!
« on: 24 Sep 2014, 10:28 pm »
I am thinking about buying an Oppo 103d.  Sure I will be using it for BluRay on my 60" Panasonic ZT Plasma.  But the other reason is hopefully running my Dish receiver through the Oppo and upping the video from 720p/1080i to 1080p plus utilizing the Darby (probably set to no more than 35)
just wondering if anyone else is doing this and if you are having a great result or if you are having hdmi handshake or audio synching problems
I am currently using a 722k receiver but am thinking about changing over to the Hopper as it would actually be cheaper.
Randy
John Casler
Re: Dish Network with Oppo 103d
« Reply #1 on: 24 Sep 2014, 10:40 pm »
Being an OPPO dealer, I have had the opportunity to use a variety of HDMI sources with the 103d.
Cable boxes, Apple TV, Computers, and any HDMI source should work fine.
What I have not had a lot of time with, is the darby adjustments themselves and plan on it this weekend, to see the effect.
I have not noticed any "lip sync" issues so far via the OPPO.
rklein
« Reply #2 on: 25 Sep 2014, 10:53 am »
Hi John
Thanks for replying.  I will be interested hearing what you think after using the Darby and what setting you like the most.
Regards
Randy
