0 Members and 1 Guest are viewing this topic. Read 9293 times.
I've read in a couple of places where guys I respect have gone the cheap/easy route of just piling rolls of fiberglass batt insulation (still in the plastic bags they came in)-.
Yes, I think that we have strayed a little from the original post however, that's OK.-
Although I agree with many of the posts thusfar, I think that fiberglass is somewhat less practical. Now I see a post of someone wanting to purchase 12 bats of fiberglass! Let's be real.
I do understand from a physics point of view that compressed hard panels of fiberglass would be a great absorber when used properly; but is it safe?-
If using a punching bag can yeild results similar to using 4, 6, or whatever number of fiberglass don't you think this would be a viable option?
If some of you could achieve good results from using canvas bags, especially since they are not too expensive, don't you think it's worth a try? Shish! Stay focused people.
Yes. You only need to make sure that you do not lick or eat the fiberglass and you should be fine. You may have heard that some homes use fiberglass in the walls and very few people die from this.
Deaths from Automobile accidents injury: 42,443 deaths in USA 2001 (CDC); 42,401 deaths reported in USA 1999 for "motor vehicle accidents" (NVSR Sep 2001)
