Old followup to lab guidelines
0 Members and 1 Guest are viewing this topic. Read 1173 times.
dayneger
« on: 22 Jan 2004, 08:04 pm »
Hi John,
Could you briefly clarify what the difference is between The Lab and Constructor's Corner?  I don't understand the need for 2 areas yet, and their guidelines overlap with DIY, construction, etc.
The Lab--The technical side of audio. How and why our equipment works, construction, and DIY.
Contructor's Corner--Threads devoted to construction of audio equipment.
Dayne
JohnR
« Reply #1 on: 22 Jan 2004, 10:34 pm »
Um, yes, haven't written the Guidelines for that one yet. It will all become clear (I hope!!) soon  :D
ratbbb2
Dynaco st70 Woes
« Reply #2 on: 12 Jul 2004, 10:30 pm »
Ok so I know I should have a grip on tubes if I own them but  up until now I haven't had any thing go wrong (other than a bad recterfier valve)
 I had Groovetubes  EL34 (JJ, Penta...) in the amp and one of the quad went bad (started  to glow and poped the fuse). I changed the fuse then played with the biasing and switched tubes to come to that conclution. ones I replace the  old(er) EL34 for a set of 6CA7 (Ei big bottle)  I can no longer get the recomended voltage of 1.56 in fact the highest it goes is 1.24v on one side and 1.21v on the other . Is there a reason for concern once I bias them at 1.15v or is it just a lower output tube?
 Thanks Roger  :?:
