Teflon coated silver wire for Bugle input output??
0 Members and 1 Guest are viewing this topic. Read 1937 times.
Julien43
I would like to use 36 AWG medicial grade wire for the input/outputs. Is there any special considerations, downsides I should be aware of. I use this stuff in my ICs and they sing in my system. It's not just a matter of what I have around. I'm hoping for a synergy.Any thoughts you may have will be greatlly appreciated!!
hagtech
« Reply #1 on: 6 Sep 2004, 05:29 am »
36AWG should work fine.  I would only suggest you twist the input pairs.  They can be really sensitive to hum and other noise pickup.
jh :)
macdaddy
    • http://macdaddys.info/
« Reply #2 on: 1 Aug 2005, 08:50 pm »
where would you get some of this wire..? i have seen others recommend this stuff, as well (and i am about to build a bugle :P)...
ohenry
« Reply #3 on: 2 Aug 2005, 10:03 pm »
I used some nice 23 ga. silver from percyaudio.com.  I inserted it into teflon tubing.
macdaddy
« Reply #4 on: 3 Aug 2005, 03:00 pm »
thanks for the reply, ohenry...
did you end up getting the teflon from thesame supplier as the wire, or did you go someplace else for the teflon..?
tia
ohenry
« Reply #5 on: 3 Aug 2005, 03:19 pm »
I think I did get the teflon there, they do stock it.  That wire has one of the highest purity ratings I've seen (7 - 9's).  I've made some interconnects using it as well with good results.
