For Sale: Speakers & Speaker Stands
FS: Thiel 1.6 Speakers in Black.....Los Angeles area pick up only.....$725
0 Members and 1 Guest are viewing this topic. Read 1372 times.
sfig
19 Sep 2014, 11:48 pm »
Thiel CS 1.6 speaker pair for sale for $725 for pick-up only in the Los Angeles area...I have no boxes so I can’t ship them.
These speakers are in excellent functional condition. You can find several excellent reviews on online. Everything works exactly as it’s supposed to without any issues. Cosmetics are good. There are some scratches on the cabinets that you may want to touch up. Rated 6 only for cosmetics as there are no functional issues. I have tried to show these in the pictures. I have taken the cosmetics into consideration in pricing these very low. The original price was $2400 for the pair.
Description: Two-way, magnetically shielded, floorstanding loudspeaker. Drive-units: 1" (25mm) aluminum-dome tweeter, 6.5" (165mm) metal-cone woofer with 3" voice-coil. Crossover frequency: 3kHz. Crossover slopes: first-order, 6dB/octave. Frequency response: 50Hz-20kHz, ±2dB. Phase response: ±10 degrees maximum. Sensitivity: 90dB/W/m. Nominal impedance: 4 ohms, 3 ohms minimum. Recommended Power: 50-300W. Dimensions: 35.5" (902mm) H by 9" (229mm) W by 11.5" (292mm) D. Weight: 38 lbs (17.3kg) each.
