FS: LSA Statement Integrated Amplifier - SOLD
0 Members and 1 Guest are viewing this topic. Read 3281 times.
johzel
« on: 19 Sep 2014, 09:17 pm »
SOLD
For Sale:  LSA Statement Integrated Amplifier with Phono Stage in the much preferred black/wood accent finish.  Mint Condition, less than one year old.  Asking $2699.00 (Or Best Offer) shipped/insured to CONUS. (a HUGE savings!!)
Get the black STATEMENT model at the silver Signature price!!!
I am going back to a preamp/amp combo so am making this available.  Lots of great reviews – check them out!!  Yup, it's that good.
The LSA Statement Integrated amp is a state of the art tube/hybrid 150 watts per channel remote controlled integrated amplifier. They retailed through dealers for $11,500.00.  They are now sold Internet Direct at $4499.00 (currently on sale at $3999.00). The Statement is the top of the LSA line and a world class amp. It has quite a good MM phono stage as well as one XLR and 3 RCA analog inputs.
The extensive upgrades to the Standard amp to make it a Statement include:
- Installation of the LSA proprietary Active Tube Load circuit in the cathode follower section of the preamplifier
- High voltage current regulator that controls current going through the tubes resulting in high impedance, high bandwidth load to tubes. This lowers distortion of the tubes enabling them to operate more linearly. It also eliminates current variations in tubes, allowing lower current going to tubes, thus increasing their lifespan
- Upgrade all capacitors in preamp section to double metalized polypropylene
- Upgrade all resistors in preamp section from carbon film to metal film
- Upgrade wiring from amplifier section to speaker terminals to Straightwire high purity copper cable
- Hand solder wire at speaker terminals vs. speaker terminal blocks
- Add a second transformer to achieve dual mono operation in the preamp section
- Change configuration of large toroid transformers to achieve dual mono operation in the amplifier section
- Add proprietary circuit board to achieve separate voltage regulation of input and driver stages of the amplifier section
- Upgrade amplifier feedback loop parts
Specs:
Finish: Black, Wood Accents
Rated Power (8Ω): Greater than 150wpc / 300 watts into 4 ohms
Total Harmonic Distortion: Less than 0.1% (1KHz)
Recommended Loading Impedance: 4-8Ω / Stable into 2 ohms
Frequency Response: 20Hz-32KHz (±1dB)
Signal-to-Noise Ratio: Greater than 90dB
Channel Separation: Greater than 60 dB (1KHz)
Input Impedance: 47KΩ
Input Sensitivity, Analog: Greater than 1.5v Input Sensitivity, Phono: Greater than 4mv
Inputs: 1 balanced, 3 single-end, 1 phono
Standard solid state preamp out for a subwoofer
Dimensions: 17" (W ) x 9 1/4 " (H) x 19 1/2" (D)
Weight: 78 pounds / 93 pounds shipped
FWIW, first picture of amp still has the protective covering over the glass.
« Last Edit: 13 Oct 2014, 05:05 am by johzel »
johzel
Re: FS: LSA Statement Integrated Amplifier - Black/Wood Accents
« Reply #1 on: 25 Sep 2014, 01:07 pm »
Price Reduced to $2699 OBO.  Get the Black/wood STATEMENT model for the silver Signature price!!!  :thumb:
johzel
« Reply #2 on: 6 Oct 2014, 01:21 pm »
Bump.  Great amp that would have cost you nearly $13,000 just over a year ago.  Going to RMAF from east of the Mississippi.  Pick the amp up on your way home!!  :thumb:
