Songtowers and VSTs - Distance From Back Wall
0 Members and 1 Guest are viewing this topic. Read 1460 times.
ckullmann1
« on: 19 Sep 2014, 04:19 pm »
Dave Upton's Veracity HT2-TL review suggests that the HT2-TLs need a decent amount of room to breathe - 3 feet from the back wall in his optimal position.  I have the Std. STs and am looking to upgrade to the VSTs.  Do the VSTs and HT2-TLs need more room to breathe than the Std. STs?  My STs are currently about 2 feet from the back wall, but they can't be moved out any further.
Big Red Machine
Re: Songtowers and VSTs - Distance From Back Wall
« Reply #1 on: 19 Sep 2014, 04:31 pm »
If ported, you could move the port to the front and keep your location assuming the response is still adequate there.
jsalk
« Reply #2 on: 19 Sep 2014, 05:18 pm »
All speakers benefit from greater distance to the rear wall.  The Veracity ST's and HT2-TL's could use a little more room.  But if the Supercharged SongTowers are working for you at 2 feet distance, the ST's would likely work as well.  We recommend 18- 24" minimum and you are at 24".  You should be good.
- Jim
Ace Deprave
« Reply #3 on: 19 Sep 2014, 06:06 pm »
I have my VSTs slightly toed in with the closest corner to the back wall being 26".
