converting a class d amp into a subwoofer amp?
0 Members and 1 Guest are viewing this topic. Read 2119 times.
motosapien
« on: 19 Sep 2014, 03:49 pm »
Are the adustable cross over and phase something you can create?  Maybe just an analog mini dsp would do the trick?  It does not take long to collect extra amps not to mention speakers in this hobby.  Appreciate some learned opinions.
mikeeastman
Re: converting a class d amp into a subwoofer amp?
« Reply #1 on: 19 Sep 2014, 06:05 pm »
I don't know about learned  :roll: But I use a Dodd built classD amp to power my bedroom sub and I use a DESpeaker 8033-s as the x-over, works fine.
motosapien
« Reply #2 on: 19 Sep 2014, 06:30 pm »
Now that is a trick bit of kit.  Some what above my price range though (300 euros).
JRace
  • Greetings one and Everyone!
« Reply #3 on: 19 Sep 2014, 07:15 pm »
yes, a sub amp is just an amp with xover, phase eq...etc.
If you have a home theater AVR with sub preout then you don't need xover of EQ.
Phase may not be needed depending on the room, main speakers and location.
*Scotty*
« Reply #4 on: 19 Sep 2014, 08:58 pm »
You might want to look at the Behringer NU3000 iNuke Ultra-Lightweight, High-Density 3000-Watt Power Amplifie. If you buy the one with the built in DSP you have the crossover and digital delay you need to optimally set up your subs. This model or the next one up are on my short list to use with my rear subs.
It looks like a near perfect solution which puts digital delay and variable crossover points in one box.
http://www.amazon.com/Behringer-NU3000DSP-Ultra-Lightweight-High-Density-3000-Watt/dp/B005EHINAS/ref=sr_1_1?ie=UTF8&qid=1411181285&sr=8-1&keywords=Amazon.com+Behringer+NU3000+iNuke+Ultra-Lightweight%2C+High-Density+3000-Watt+Power+Amplifier
Scotty
« Last Edit: 20 Sep 2014, 02:49 am by *Scotty* »
motosapien
« Reply #5 on: 19 Sep 2014, 09:00 pm »
I'm a 2 channel hold out.  Don't watch the tele.
*Scotty*
« Reply #6 on: 19 Sep 2014, 10:07 pm »
I am also a two channel Luddite. I run the subs on the rear wall of my living room to help achieve flat bass response. I have two 12in. woofers per side in the floorstanding loudspeakers in my system and being flat to 18Hz. they load the room pretty hard.  The out of phase subs(180degress) in the rear tighten the bass up and reduce any room resonances. Strangely, they also improve the imaging. When you do nothing more than turn off the rear subs, the imaging becomes more 2 dimensional and stuck in the front half of the room.
Scotty
randytsuch
« Reply #7 on: 19 Sep 2014, 10:35 pm »
Hey Scotty
I was looking at those DSP Behringers
http://www.amazon.com/Behringer-NU1000DSP-iNuke-Power-Amplifier/dp/B005EHIN3A
And year, I agree, seems perfect for a sub.  A minidsp would work too, but for the price the Behringer looks really nice.
Randy
*Scotty*
« Reply #8 on: 19 Sep 2014, 10:48 pm »
It appears perfect for implementing the Controlled Acoustically Bass System (CABS). The linch pin is digital delay of the correct duration which
the Behringer iNuke amp appears to have.
Scotty
richidoo
« Reply #9 on: 20 Sep 2014, 04:05 am »
Or the Crown XTi 1002. Similar function, much better reliability for $180 more.
http://www.amazon.com/Crown-XTI1002-U-US-XTi-1002/dp/B004ZGBLJO
You can DIY analog sub controls per your OP with plans and PCBs from here:
http://sound.westhost.com/projects-0.htm#xvr
Project 09 for the XO and Project 103 for phase. Also need power supply for the opamps.  Also some good articles linked on those project pages about subs. If you can position the sub at same distance to your ear as the main speakers then you don't need the phase.
If you have low output impedance on your preamp/source and high input impedance on your class D amp then you might get away with a passive, line-level crossover filter. It's only good for 12dB octave slope. A 24dB/oct slope will require a current buffer, like project 09 circuit above.  But it's worth a try, super cheep.
http://www.t-linespeakers.org/tech/filters/passiveHLxo.html
motosapien
« Reply #10 on: 20 Sep 2014, 09:43 am »
Thank you for all the suggestions.  My initial application is to run woofers from 90 on down in a bi amped set up.  If I did not already have the class d amp I surely would have used a plate amp.  I may still considering the costs involved with these pro amps.
Bob in St. Louis
« Reply #11 on: 20 Sep 2014, 11:42 pm »
If you're looking for the controls, but not the amp, this might be what you want:
http://www.reckhorn.net/pages/active-x-over.php
Hope that helps!
Bob
