0 Members and 1 Guest are viewing this topic. Read 3357 times.
I would say you will notice quite a large difference. With the rug, you'd at least still be absorbing the early reflections off the floor - but note a 5x8 rug is only 15% of the surface area of the floor - not very much. So you're removing quite a lot of absorption that the carpet is giving. However, carpet doesn't typically absorb in a perfectly broad fashion and it can definitely create issues where it absorbs a lot at certain frequencies and not much others, which can give decay time imbalances. Having a solid reflective floor will mean the decay will likely be a bit more even, but it also will be longer and more pronounced. It may be a pleasant change due to this, but the increase in flutter, reverberation, and other reflections could make it less pleasant.
I'm considering changing out the carpet in my 13' x 20' x 8' den where the audio system resides. I'm thinking about going with wood or tile flooring. Either way, I'll have at least a 5' x 8' rug in the middle of the room. My reluctance with pursuing wood or tile is the change it will make to the sound of my system. However, I don't know if the change will be subtle or dramatic, nor can I predict how the sound will change. The room is untreated and will remain so. Any thoughts or ideas? Thanks.
In an untreated room it will be a minor change. It's just affecting the highest frequencies and only on one surface (floor).Since the room is untreated you will probably perceive this as an improvement. If you had a good acoustical designed room it would have a bigger impact.Wood floor can give a more physical feeling if you have subwoofers, since it can resonate a little.
