0 Members and 1 Guest are viewing this topic. Read 16496 times.
Most of those with fairly ordinary pivoted arms actually do not. The degree of offset of lateral forces that might arise from a few degrees even of non-level condition are just simply SMALL when compared to what results from the lack of precision that most all of us can regularly achieve with our anti-skating force settings. My recommendation is to not sweat the leveling thing too much..." If you have a pivoted style arm.
Don't underestimate the benefit of perfectly level, even with a gimbaled arm. Differences might be hard to quantify, but with a "good" set-up you'll hear it.What if you have a unipivot? If the record is on an angle much more than anti-skate is affected. You're putting more force on one groove wall than the other. This will give not only unbalanced sound, it encourages mistracking. What's the big deal? Level it. You'll be glad you did. BTW Harbor Freight has a nice bubble level for under a dollar. neo
What's the big deal? Level it. You'll be glad you did. neo
These things are hard to quantify in real terms.
It is also hard on the platter bearing, and this alone may be one of the most important parts to getting a table level. It's almost no effort to hold something in your hand that is level and balanced, try to hold something off center....
A very nice level indeed. Do we really need a $150 level for normal turntables with pivot arms and oil bearings? I think it might be a little beyond the scope of the op, a person new to vinyl without an air bearing tonearm. Despite it being a really nice looking tool.
I bought a bunch of dollar store levels - smaller torpedo levels. Not one of them was actually level. Put the level on a non-level surface and take a reading, then turn it around and it should be the same. If you get different readings which is right?
