FS: Yulong Audio Sabre DA8 DSD 32bit/384KHz DAC - SOLD
0 Members and 1 Guest are viewing this topic. Read 2928 times.
StevenZ
Hey folks, up for sale is my 4 month old Yulong DA8 DSD DAC.  I bought it from Grant Fidelity 4 months ago for $1200.  The DAC sounds phenomenal with all media I've played through it, from 16/44 to DSD.   Everything works perfectly and this unit can be used as a standalone DAC/Preamp as well.  The unit was delivered with a small scratch on the top of the chassis which I have pictured.  The scratch is not deep and is also colored in which tells me the scratch was there before the anodizing process happened.  Honestly, it's hardly noticeable unless you're very close to the DAC and looking for it.  I'm asking $900 $850 $825 delivered (Last reduction, last call).  CONUS only.  Paypal only.
Taken from Yulong's website:  (For full details and additional specifications click here http://www.yulongaudio.com/en/product_detail.asp?pid=30 )
Specification:
THD+N less than 0.0003%, dynamic > 130dB, Idle noise 1.5uV
USB supports 32bit, 384KHz PCM signal
DSD native support
5 different filter mode
Invertible phase
Jitter eliminator switch
Filter, phase, jitter control switch. Different style of sound under different combination
High precision bandwidth-auto-set DPLL
80 steps volume control
Single/Balanced pre-amplifier output
Balanced pre-amplifier output with driver, can be used as balanced headphone amplifier
Work as pure DAC when headphone amplifier and pre-amplifier circuit turned off
Class A single end headphone amplifier
TFT LED display. Easy operate. 80% dim after 5 seconds
Auto-save configuration
Thickened aluminum case. Aluminum button, volume knob and feet
100v-240v global voltage range
« Last Edit: 1 Oct 2014, 06:46 pm by StevenZ »
StevenZ
Re: FS: Yulong Audio Sabre DA8 DSD 32bit/384KHz DAC
« Reply #1 on: 13 Sep 2014, 07:53 pm »
Weekend Bump
Tubeburner
« Reply #2 on: 14 Sep 2014, 02:08 am »
This dac is one of the best, especially for the money. I don't know the seller, just my opinion.  :thumb:
StevenZ
« Reply #3 on: 15 Sep 2014, 07:30 pm »
Reduced price to $850 $825 shipped.  Last reduction, last call.
« Last Edit: 18 Sep 2014, 08:40 pm by StevenZ »
StevenZ
Re: FS: Yulong Audio Sabre DA8 DSD 32bit/384KHz DAC - REDUCED!
« Reply #4 on: 18 Sep 2014, 08:43 pm »
Folks, if you're been dying to dip your toes into DSD and high resolution audio this is your ticket.  It's a fantastic sounding piece that can be the cornerstone of a true reference system.  Do yourself a favor and read up about this DAC, it's exceptional and is packed with high quality name brand parts.  Price was just reduced on first post and previous.
Tubeburner
« Reply #5 on: 27 Sep 2014, 04:20 pm »
Smokin deal on a really nice sounding dac. This sounds exceptional on redbook let alone DSD. I'm listening to mine right now.  :)
StevenZ
Re: FS: Yulong Audio Sabre DA8 DSD 32bit/384KHz DAC - SOLD
« Reply #6 on: 1 Oct 2014, 06:47 pm »
SOLD!
