SP3 - IR codes & remote?
0 Members and 1 Guest are viewing this topic. Read 1294 times.
Grit
  • - Garrett
« on: 10 Sep 2014, 08:32 am »
I finally got my SP3 connected. SO MUCH GOODNESS!
Two quick questions:
- Where can I get a CCF file with the IR codes?
- The documentation says a remote is included, but I can't find a remote. Is this an error, or did I miss the remote somewhere?
- Garrett
  • The Demo is Everything!
    • http://www.bryston.com
Re: SP3 - IR codes & remote?
« Reply #1 on: 10 Sep 2014, 10:42 am »
HI
Yes remote is included - check the box again - I assume you bought it new?
Codes - email Mike at Bryston - [email protected]
james
So There
  • Brystonized
« Reply #2 on: 10 Sep 2014, 03:11 pm »
Congratulations, Garrett!  :thumb:  I'm sure you'll be delighted with the SP3.
Happy listening,
Rich
___________________
Still Shakin' Napa Valley
Grit
  • - Garrett
« Reply #3 on: 11 Sep 2014, 05:07 am »
HI
james
Thanks James, Mike emailed me the hex codes. After diagnosing a problem with my RF on my programmable remote, I have a few test codes in and all appears to be working properly.
I rechecked the box and foam packing stuff. Unless there's a secret compartment in the foam that I missed (I looked, just in case it was sandwiched between to pieces), there is/was no remote included. And yes, it's new. Serial is 0706 I believe.
- Garrett
« Reply #4 on: 11 Sep 2014, 11:31 am »
I am at the CEDIA Audio show this week in Denver so please email Mike and ask him to send you one - Black or Silver?
james
BrystonFan
« Reply #5 on: 11 Sep 2014, 10:24 pm »
Welcome to the SP3 family Garrett  -  you will love it!
Grit
  • - Garrett
« Reply #6 on: 12 Sep 2014, 06:46 am »
james
Thanks James. Hope you're having fun at CEDIA!
My poor SP3 musta had a bad day before it left Bryston. Part of the screen (blue) has an intermittent flicker. Is the screen something I can swap out here at home, or would it need a round trip back to Canada? I figure if its just taking the top off, unplugging a ribbon cable and swapping them, maybe I could save the down time?
It doesn't seem to be affecting performance. Just one of those things where you want everything to be perfect.
The below image isn't mine, I just borrowed it off the internet. The area on the screen that has the occasional flicker is where the Dolby Digital double D's are at (line 2, after "IN" and before "Dolby TrueHD 7.1" It seems to be more pronounced when the input display is "Unknown". The affected area appears to be just the two characters where the DD is at.
