Spruced up Music Hall TT--MMF-5SE
0 Members and 1 Guest are viewing this topic. Read 2367 times.
Tonto Yoder
« on: 4 Sep 2004, 10:20 am »
Walnut plinth and sorbothane added. $899 was the price I saw.
dogberry
« Reply #1 on: 4 Sep 2004, 04:20 pm »
I think the tonearm was beefed up and something else.  Can't remember.  I hope this offer this SE package for the MMF-7.
Tonto Yoder
« Reply #2 on: 4 Sep 2004, 05:57 pm »
You're now able to use your choice of interconnects, so there must be RCA jacks on back rather than a captive/fixed patch cord.
Chops
« Reply #3 on: 15 Sep 2004, 12:16 pm »
Actually, I have an mmf-5, and that tonearm looks the same as mine. I did replace the cheap felt mat that came with it with a foam one which helped out alot. No static at all!
JoshK
« Reply #4 on: 15 Sep 2004, 12:43 pm »
IMO, the real drag on the performance of the MMF5 is the tonearm.  Don't get me wrong, the MMF5 is a great entry point to Vinyl, but I really never cared for the arm.   The planar 3 I had had a far better arm but I think the table is better on the MMF5.   Too bad noone has come out with a Rega mount for the Musichall tables.  Might be the cats meow of budget tables.
Chops
« Reply #5 on: 15 Sep 2004, 04:16 pm »
I know what you mean. The arm isn't exactly the smoothest or most precise one I've seen. Oh well, it does what it is supposed to anyway, and that's all that matters.
However, I did replace the stock Goldring 1012GX cart with a new Shure M97xE which I feel is a huge step up in performance! At least to me ears.  :D
Psychicanimal
« Reply #6 on: 15 Sep 2004, 10:22 pm »
***  No comment  ***
Chops
« Reply #7 on: 15 Sep 2004, 10:37 pm »
Quote from: Psychicanimal
***  No comment  ***
Oh brother, here we go already.....
Just what exactly is that supposed to mean?!
JoshK
« Reply #8 on: 15 Sep 2004, 10:39 pm »
Just let it go man....
Chops
« Reply #9 on: 15 Sep 2004, 10:44 pm »
Yep.  :wink:
