Empirical Audio launches the Power Block USB cable filter/supply
0 Members and 1 Guest are viewing this topic. Read 3678 times.
audioengr
If you use USB to your DAC or USB converter and your device needs the +5V power in the cable, such as Berkeley etc., then the Power Block can upgrade your sound quality significantly.  See:
http://www.audiocircle.com/index.php?topic=128620.0
Steve N.
Empirical Audio
