Bryston Middle T Amp recommendation
0 Members and 1 Guest are viewing this topic. Read 1183 times.
Scar
« on: 6 Sep 2014, 05:36 am »
Hello. How are you people? Apart from Bryston Amps/Pre does anyone have any experiences with other brands that match up well with the fabulous Middle T's?
I would consider tube although I am not too familiar with them. Also an integrated is possible. like to keep it around 3k for cost.
I listen to mostly rock, new and old. Pop, some jazz, blues etc. Room size is 12 ft by 18 ft opening up to a 10 by 12 ft kitch.
Any info is appreciated.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston Middle T Amp recommendation
« Reply #1 on: 6 Sep 2014, 12:54 pm »
Hi Scar
Did you purchase the Middle T's?
james
Scar
« Reply #2 on: 6 Sep 2014, 06:31 pm »
Yes. On order.
« Reply #3 on: 6 Sep 2014, 06:52 pm »
Yes. On order.
Ok great - Can't wait to hear how you like once set up. :thumb:
james
