plastic foot dissolved
0 Members and 1 Guest are viewing this topic. Read 1695 times.
gagamut
« on: 31 Aug 2014, 08:20 am »
Hi my Amadeus GT is old version,today i found the plastic foot dissolved, :oso need to replace,any suggestion?? squash ball is OK? what type??soft ,medium or hard?need cut half ??
ADiG
Re: plastic foot dissolved
« Reply #1 on: 31 Aug 2014, 09:04 am »
There is a conversion kit with 4 cylinder and 4 squash balls Oliver - the original hardness of the balls is red.
Ask mr Pranka.
NB: Oliver balls (Amadeus) produced here, are better than those (same brand) supplied:
http://www.ebay.it/itm/Oliver-Squashballe-Squashball-blau-rot-gelb-doppelgelb-1x-3x-6x-Packungsgrose-/151023735605?pt=DE_Sport_Schl%C3%A4gersportarten_Zubeh%C3%B6r&var=&hash=item2329b75335
« Last Edit: 31 Aug 2014, 03:33 pm by ADiG »
gagamut
« Reply #2 on: 31 Aug 2014, 10:07 am »
thanks for help :D
gagamut
« Reply #3 on: 31 Aug 2014, 10:10 am »
is it need to cut half??
ADiG
« Reply #4 on: 31 Aug 2014, 11:01 am »
with the conversion kit, the balls should be used whole  :)
gagamut
« Reply #5 on: 31 Aug 2014, 01:34 pm »
where to buy the conversion kits??
gagamut
« Reply #6 on: 31 Aug 2014, 01:35 pm »
can bought from Mike Pranka??
ADiG
« Reply #7 on: 31 Aug 2014, 03:30 pm »
I live in Italy but I know that the owner of this forum is the distributor of WTL (Mike Pranka).
In this site (Portugal), in the bottom of the page WTL, you can see what you are looking: http://www.audioteam.pt/
