Two New Woofers to OB
0 Members and 1 Guest are viewing this topic. Read 3564 times.
« on: 22 Aug 2014, 11:57 pm »
Just recently I aware there is a nice local speaker manufacturer that is mading some finest woofers to OB similar in price to the Alpha15A, inexpensive so.
The woofers line had many drivers, but I found two especially suited to OB, a 12 and a 15 inches:
12'':
http://www.parts-express.com/pedocs/specs/294-2730-prv-audio-12w700-specifications-4111.pdf
http://www.parts-express.com/prv-audio-12w700-12-high-power-pa-woofer-8-ohm--294-2730
15'':
http://www.parts-express.com/pedocs/specs/294-2740-prv-audio-15w700-specifications-2118.pdf
http://www.parts-express.com/prv-audio-15w700-15-high-power-pa-woofer-8-ohm--294-2740
PartsExpress informed the 15'' do F3=20Hz in a 504L BR box, for $69 is not bad.
Manufacturer site:
http://prvaudio.com/
Guy 13
Re: Two New Woofers to OB
« Reply #1 on: 23 Aug 2014, 03:25 am »
12'':
15'':
Manufacturer site:
Hi FULLRANGEMAN.
I just finished looking at the specs for those woofers you mentioned in the links
and they are very similar to my Eminence Acoustinator.
I am sure you will be happy with the sound.
Thanks for sharing, let us know which one you choose.
Guy 13
Since I am a bass lover, I am highly interested in your project.
Of course pictures of your project would be a plus,
but I know already that you don't have a camera, too bad,
because a picture is worth a thousand words.
« Reply #2 on: 23 Aug 2014, 05:35 pm »
After two months sending inquiries I giveup the Eminences by lack of email reply from the brasilian distributor and short after find this local brand.
For pair the Omega I have choose another woofer not mentioned above, its the 12W750A :
http://prvaudio.com/pdf/12W750A_Datasheet.pdf
The paper cone is very light MMS=39gr only.
The remaining prob is I cant decide if I will run the Omega solo or a two way with this woofer for more slam with prog rock!
Help appreciated.
JohnR
« Reply #3 on: 26 Aug 2014, 05:19 pm »
Hi Gustavo, that last 12 doesn't look very suited to use as an OB woofer. The 15 in your first post would be a better bet, AFAIC.
« Reply #4 on: 26 Aug 2014, 07:28 pm »
Yes the 12W750 aren suited to OB, the about Qts=0.5 is not nice to OB.
I say it my choice to pair the Omega FR why I will use it in a bassreflex ducted box around 150-200lts, where I think it would work with a 15W 6C33 amp.
mcgsxr
« Reply #5 on: 26 Aug 2014, 10:48 pm »
If it were me, and I were looking to run them in actual OB, I would go with the 15 for sure.
They both have similar QTS and XMAX (2 of the 3 critical specs in my mind), but the 15 has a much lower FS which should lead to more satisfying bass in room.
Not saying you cannot try it on OB, I usually try every woofer I come across!
