Bedini clarifier
0 Members and 1 Guest are viewing this topic. Read 867 times.
Charles Calkins
Bedini clarifier
« on: 2 Sep 2004, 05:19 pm »
Hi Guys:
  Anybody try the Bedini dual beam ultra clarifier. From what I've read it sounds pretty good. But as we know! Can't believe everything we read.
                       Cheers
                       Charlie
electricbear
re- bedini
« Reply #1 on: 2 Sep 2004, 05:42 pm »
I do not use of sell these but I have several customers that do and they all swear by them.  Better ,clearer bass and extended highs.
TheChairGuy
Bedini clarifier
« Reply #2 on: 2 Sep 2004, 06:58 pm »
I use the older (cheaper) hand held (I assume single beam) Bedini before evey play.  Modest improvement overall - slightly cleaner presentation. Before modding the front end I thought it's effect was more substantial...now, fairly incremental only.
I read somewhere that the (more expensive) dual beam unit was brought out becasue of the higher density of DVD discs...that the single beam unit is sufficent for CD's...if that's all you'd use it for.
Who knows...... :scratch:
