DIY dust over for Amadeus
G E
« on: 19 Aug 2014, 12:52 am »
Has anyone fabricated a dustcover for their Amadeus tt?
Any tips or hints you can share?
watercourse
Re: DIY dust over for Amadeus
« Reply #1 on: 19 Aug 2014, 01:04 am »
An old Moto Guzzi handkerchief works great for me.
I may be making one out of 1/4" wooden dowels glued and tacked for a frame, and my wife will help with attaching fabric over the frame (her choice) that will be at home in our living room. I started one for the Simplex, but didn't actually complete it, so can't say how well it works.
G E
« Reply #2 on: 19 Aug 2014, 02:38 am »
A while back I was gathering up and putting away various lengths of bubble wrap. That stuff is expensive and I like to reuse what I can.
I got to wondering if sections of bubble wrap, the version with the bigger air cells, might be fashioned into a cover. There is some structural rigidity and maybe a cone-like structure could be created. A cone head dust cover if you will.  Really.
I got sidetracked by something else but perhaps I will revisit the idea. Double sided tape or those 3m magic sticky squares with the tenacious holding power might work to join segments.
I'll give it more thought
