Modded Denon 103's.
0 Members and 1 Guest are viewing this topic. Read 1621 times.
mick wolfe
Modded Denon 103's.
« on: 11 Aug 2014, 05:52 pm »
I was about to send a 103 of to Zu for an Aluminum body. Then I started to wonder if the additional weight would be a compatibility issue with the Amadeus arm? Any experience here with the wood or alum. body 103's? Or heavier carts in this weight range( 14.5g) for that matter. Thx.........Mick
Maniac
Re: Modded Denon 103's.
« Reply #1 on: 12 Aug 2014, 02:12 pm »
Thought about doing same thing.  Let us know how you make out if you pull the trigger.
mick wolfe
« Reply #2 on: 13 Aug 2014, 10:45 pm »
At this point, my finger is off the trigger. It looks like more research is in order. Didn't realize it bumped up the weight by 6 grams. ( Zu alum. body)
mick wolfe
« Reply #3 on: 13 Aug 2014, 10:59 pm »
Just got a hold of Mike Pranka. The use of heavy carts is fine. Just use both counterweights to compensate for the cart's additional weight. May have to tweak the damping a bit as well by adjusting the silicon vat.
