Rega P1 w/AT440mla cart height question
0 Members and 1 Guest are viewing this topic. Read 1301 times.
NIGHTFALL1970
« on: 7 Aug 2014, 11:50 pm »
I have read that Rega carts have a different height than most others and if you use a different (non-rega) cart that the height may be wrong.  Do I need to add shims to the Rega for use with the AT440mla?
plastico
Re: Rega P1 w/AT440mla cart height question
« Reply #1 on: 8 Aug 2014, 05:20 pm »
Rega carts are 14mm in height. So the general rule is adding the shim that is the  difference in height. I see that your cart is 17.3mm tall. A 2mm - 4mm shim would be needed. Everybody has a different taste, so listen, and and see what works for you.
Cheers, Plastico
NIGHTFALL1970
« Reply #2 on: 9 Aug 2014, 10:38 am »
Plastico,
thanks for the reply.  I will look into getting some.
bacobits1
« Reply #3 on: 9 Aug 2014, 02:30 pm »
Yup different tastes. When I had my Rega a 4mm height or 2 X 2MM is what I used worked well with all non Rega Cartridges. You can try  a lined index card to check parallel at the headshell only area since the arm is tapered.
Should be pretty close to level.
NIGHTFALL1970
« Reply #4 on: 22 Dec 2014, 09:44 pm »
Added the Rega three point spacer set at 4mm.  I can't believe the difference!  More separation between instruments, more sense of transition between highs and lows.
Anyone else have this experience?
P.S. The only disadvantage to this setup is that I have to remove the dust cover when I play anything, as the counterweight hits the cover.
« Last Edit: 23 Dec 2014, 10:55 am by NIGHTFALL1970 »
orthobiz
« Reply #5 on: 23 Dec 2014, 05:21 pm »
Cool, BUT I would think the Rega Cart on the Rega Table would be at the perfect height without a shim...guess not!
Paul
